f54 block and p90 head
Guest isaac240z
Guest isaac240z
hi guys ! i cant dicide what motor should i used.. when i bought my 1970 240z, i came with the f54 block and the p90 head with factory carbs (su) and it runs good with the carbs.. my target is around 350 or 400 whp, after the turbo, intercooler, porting, new hoister carb, and all that work. what internals do i need or should i swap sr20 ka24 or what do you recomen me.. my curent L28 has no turbo and its carb..
yes it "can" be done... but should it be done. its the hardest way to turbo an L28... If your gonna go turbo ... you need FI. it would cost you way more than a regular turbo set up and it wouldn't run as good. Read the book called "maximum booost" by corky bell. it has a section on carb'd turbo set ups (it even includes a photo and write up on a carb'd L28).
Matt-
