out with the cracked up t3 housing
Im doing away with the cracked up dirty turbine housing and looking for a t4 housing. What size & trim housing and turbine would be the most efficient with a .60 t04b compressor 3" inlet 2"out. The compressor wheel is 2 9/16in at the base and 1 7/8in at the top +-.03", crapy calipers not sure if it matters though. There are 8 large fins and 8 smaller fins inbetween the larger ones any help identifying it would rock, oh yeah there is an A stamped on the wheel and the tag on the housing says t04b80 if that helps. I would like to push 450+hp without having too terrible long to wait for boost. i imagine a .68 would do the trick?
i saw a video on u tube of a guy with hy35 or something and it sounded bad roasting them at 60 without tryin too hard and smokin a fairly beefy 300zxtt..i havent looked at anything but t series thusfar but im open to new things...what type of holset do 450+ guys use and by the way are 42lb injectors enough to supply those kinds of boosts
