GTO/Z Speedracer
Hi Dale - can't find my specs. on the offset but..... Without pulling the rim off (sorry it's kinda late tonight)I measure about 1 7/8" from the back of the rim to the mounting face. So, 10" rim, C/L 5" would make offset about 3 1/8".
Let me know if you need it closer because I pull the rim and get you a better measurement.
BTW, I think Dayton will make wheels with a different offset if you want them.
Hope this helps. :D
Speed, don't go pulling off any wheels on my account. Don't you also have an adapter for the knock offs? From your pictures it looks like the rear tire could go out a little more without hurting any thing, right? Here's the story. A stock Z is 53.75 wide hub to hub, my Jag rear is 62, so we've got 4 1/4 wider each side. The GTO body is what 3- 3 1/2 wider on each side? So a standard offset should be close to fitting under the fender? Not having to narrow the rear would be a little relief with all the other problems I'm getting into. Have a 65 mustang that I've stripped down for a total resto to get a little mad money. I've got the GTO in his garage and miss it. Didn't anything left to unbolt so I started cutting spotwelds. Today I started going the other way. So it won't be long till I get my goat back. Thanks Dale P.S. Do you know the man's name or e-mail address that I talked to at Carlise?
Guest Anonymous
I have a full set of Dayton wires that came with my Blue Ray GTO they are 15X8 inch. the rears are "reversed" at a 2 1/4 inch offset and the fronts are 3 5/8 inch offset. They have some really good splined adapters that can be interchanged to about any lug bolt pattern. Check with Dayton about offsets. 3 5/8 is getting in there and much more to the inside would look abnormal for traditional spokes.
Hi Dale - Yup, I have the typical Dayton adapter for the knock-offs. I just went out in the garage and measured a couple of things. I always thought I had 10" rears but they measure 9" which is the same as the front. Again, I am measuring them on the car with the tires mounted. So, I must have 8" rims probably just like the ones Tomahawk Z has.
Since the tires travel through an arc it's difficult to tell how much room is left. My guess is that you could only move the wheels out another 1/2" to 3/4 max". A great deal of that will depend on the tire you intend to install.
IMHO, if you lose to much offset it won't look right. I think 4 1/4" per side is to much to make up. frown.gif
BTW, the Michigan guy with the GTO that you met at Carlise is Dan Horton. Check your e-mail because I'll send you his phone number.
