Brad-ManQ45 Posted May 26, 2002 Share Posted May 26, 2002 kewl Mike! I'm not ready yet, but will be a customer in the future... Rotisserie, body work, suspension back on and then brakes! Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted May 27, 2002 Share Posted May 27, 2002 Sounds promising Mike. Mike wrote: the cable attaches with the stock early Z cable What do those with late (280Z) cables do? You've got my address to ship my 15 pairs to, I look fwd to getting them shortly Quote Link to comment Share on other sites More sharing options...
Guest scca Posted May 27, 2002 Share Posted May 27, 2002 finally got time to finish these off $20 PR with pins, priority mail $5 pics and install instrucions will be online tomorrow minimal grinding may be required (to keep the cable run smooth) on the caliper end but otherwise should bolt in. not sure how many i have done but near 15 pairs, i have the template now for making more so they shouldnt take as long. the picture will show a white painted area where you may want to grind to allow full movement without touching, likely not necessary but just showing for those that may want it. the cable attaches with the stock mounting point and stock early Z cable and retainer clip the cable end that goes into the extension will re-use the original drum ClevisPin and cotter pin . the other end of the extension will come with a 5/16" pin and cotter pin plus washers to hold it in the caliper Quote Link to comment Share on other sites More sharing options...
