383 240z Posted May 11, 2007 Share Posted May 11, 2007 I decided to MS-II my Jeep. I got 99% of the wiring in and buttoned up real nice. Last night the wife asked me how it was going. I turned the key over and after about 45 sec of cranking it fired and idled pretty good. She was impressed, I was happy all was good with the world!! I tried to start it today to work on the tuning, and nothing, so I hook it up to the laptop, and I'm seeing 0 RPM on MegaTune. I dont move ANY wiring pull the dizzy from the block and spin it with my fingertips, and it reads a good signal, the coil gets power, the fuel pump kicks in, I put it back in the block, No RPM. I thought some thing inside might be grounded, I pull the cap and rotor, no such luck. I did convert the dizzy to a 7 pin HEI. It is allmost like the starter cant spin it fast enough, I have the batt. FULLY charged and I cant believe that my two fingers are spinning it that much faster than the starter is. This is starting to drive me nuts, I'm about this far from getting a EDIS 6 set up for this thing!!. Keith Quote Link to comment Share on other sites More sharing options...
383 240z Posted May 11, 2007 Author Share Posted May 11, 2007 ok I have some new/relevent info to add. When the dizzy is in the block, I do get some RPM on the MT. the highest I saw was 175RPM is there a way to lower the threshold as to when power is sent to the pump/coil. or do I need to make the starter spin faster? Keith Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted May 12, 2007 Share Posted May 12, 2007 There is a setting for craking RPM under the "crank/warmup" heading (more cranking stuff). Quote Link to comment Share on other sites More sharing options...
