Lowered Sway Bar
My JTR differential flange adapter was hitting my sway bar, so I made some brackets to move the sway bar down an inch and a half. Here are the pictures, if anyone is interested:
Factory position v/s Lowered position:
Factory mounting bracket:
Lowering Brackets: 1 3/4" wide x 3 1/2" long pieces of 3/16" plate. Then made two gussets from 3/16" plate. In hindsight, 2" wide (as opposed to 1 3/4") would have been better, because the factory bracket is 1 3/4" wide, so you have to line it up just right to weld it.
Cutting-Torched the factory brackets: (btw, the torch works great for removing the undercoating :-D for later welding).
Squared up the factory brackets on a bench grinder, so they would lay flat on the brackets, then put them back on the sway bar.
Welded in the lowering brackets:
Welded the factory mounts to the lowering mounts:
Plenty of room now, and the picture is deceiving.....the bottom of the sway bar is NOT lower than the cross member, in fact it's even with it.
