280tyler Posted May 13, 2007 Share Posted May 13, 2007 i'm having trouble getting my car to run right it's a L28ET with ms1 v3 when i start it up it runs very rught it is missing a lot so i took the coil`wire off so i could see how it was sparking. in is sparking good for a couple of cycles then it cuts out for a sec then it starts sparking again and it will repeat that for as long as i crank the car. that explains the missing but what could be causing it? has any experience something like this before? i'm going to get my dizzy tested this week ans shield wm wires. i also cant see if the ta ch in mt is going crazy because mt keeps going ni to not responding when the car turns over i'm gonig tf try to get a new usb adapter to fix that? Quote Link to comment Share on other sites More sharing options...
naviathan Posted May 13, 2007 Share Posted May 13, 2007 I think your issue with spark and you not responding issue in MT are related. If your MS is reseting that would explain the dropped spark. How do you have your ignition wired up? Quote Link to comment Share on other sites More sharing options...
280tyler Posted May 13, 2007 Author Share Posted May 13, 2007 i have my ignition is wired according to the diagram on the diy auto tune site. what can cause it to reset Quote Link to comment Share on other sites More sharing options...
