Guest FTT843 Posted May 14, 2007 Share Posted May 14, 2007 Im building up a 400-450 hp 318 to go into a 240z. Now before you ask why a 318? Ill tell you. 318's are a dime a dozen, and can easily build one that pumps out 400 hp and pulls hard as hell all the way to 6,400 rpm. I know the engine is a straight drop in. But what is required to run the mopar 4spd or some 5spd from another car. Im open for recomendations. But I would like to keep fabrication to a minimum. I heard to use the mopar 4spd you just need to weld a bracket for the tranny. Is this correct? BTW what kinda 1/4's are people gerring from a car putting down 380rwhp? Thanks, Frank Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted May 15, 2007 Share Posted May 15, 2007 not alot of choices in the manuals trans. department Quote Link to comment Share on other sites More sharing options...
Pete84 Posted May 15, 2007 Share Posted May 15, 2007 http://www.moparchat.com/forums/showthread.php?s=&threadid=71020&highlight=supra That has alot of different combinations. Not sure if the Toyota R154 will take the power you're planning, but as it will be in a 240Z there would be less strain on it. Quote Link to comment Share on other sites More sharing options...
Guest FTT843 Posted May 15, 2007 Share Posted May 15, 2007 Anyone know why a mopar 4spd wont work? Im just curious Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted May 15, 2007 Share Posted May 15, 2007 I apologize Im not saying it would not work,but you would have to fab your own Linkage for the clutch or you could buy the Keisler hydraulic slave cylinder kit from http://www.Keislerauto.com. it eliminates the linkage issue...the next thing would be clearancing of the tunnel.so that the external linkage can work properly,it may or may not be an issue..what 4 spd do you plan on using? the OD or standard from an A-body(dart, Duster,Valiant, B-Body-( Charger,Roadrunner,GTX,Super Bee, Coronet etc.) or an E-body Cuda/Challenger B-E bodies have the same shifter Location the A body is farther forward... you could possibly adapt a bell housing/ hydraulic set up from truck Magnum series too,but then there is the trans issue. Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted May 15, 2007 Share Posted May 15, 2007 http://www.moparchat.com/forums/showthread.php?s=&threadid=71020&highlight=supra That has alot of different combinations. Not sure if the Toyota R154 will take the power you're planning, but as it will be in a 240Z there would be less strain on it. Ive been told the R154 will work in high power Applications Quote Link to comment Share on other sites More sharing options...
Guest FTT843 Posted May 16, 2007 Share Posted May 16, 2007 Just a plain 4spd out of a 71 cuda. Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted May 16, 2007 Share Posted May 16, 2007 it should work as long as you have the small block bell housing clutch, flywheel etc. etc how do plan to operate the clutch? you wil need the shifter and Rods/arms as well.then you will be on your way! Quote Link to comment Share on other sites More sharing options...
Guest FTT843 Posted May 17, 2007 Share Posted May 17, 2007 I have a good mopar connection for parts I should be fine on linkage. Ofcorse it will be a pistol grip shifter aswell Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted May 18, 2007 Share Posted May 18, 2007 cool make sure its from an E-body Quote Link to comment Share on other sites More sharing options...
xdabsx Posted March 21, 2008 Share Posted March 21, 2008 you could get a hydaulic set up from 90s rams in the junk yard get the bell slave cylinder master cyl reservoir pedal rod and every thing for cheap and dont have to wory about the bulky linkage. has to come from a v 6 5 speed with the nv2500 trans cause it separates from the bell. Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted May 24, 2008 Share Posted May 24, 2008 you could get a hydaulic set up from 90s rams in the junk yard get the bell slave cylinder master cyl reservoir pedal rod and every thing for cheap and dont have to wory about the bulky linkage. has to come from a v 6 5 speed with the nv2500 trans cause it separates from the bell. The gear ratios would be wrong,and the trans is not strong.. Quote Link to comment Share on other sites More sharing options...
xdabsx Posted May 26, 2008 Share Posted May 26, 2008 I wasn't saying to use the nv2500, jut get the bell housing and hydro clutch parts. He could put a jerico in it if he wants to. You could run a nv3500 if you want the bell doesnt come off though. It is am internal rail shifter so no out side linkage clearance problems and will bolt right up. I wouldn't worry about it breaking cause your car will be light. They use them in super stock Dakotas and leave pretty hard and they live. Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted June 7, 2008 Share Posted June 7, 2008 how is it going with the conversion? Quote Link to comment Share on other sites More sharing options...
Challenger Posted June 7, 2008 Share Posted June 7, 2008 I wanted to put in a 360/318 but I found a turbo motor, someday... Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted June 7, 2008 Share Posted June 7, 2008 I just found a decent Car close by(all others were rusty) my plans call for a 360 Magnum and Toyota 154r transmission Quote Link to comment Share on other sites More sharing options...
4seat74 Posted July 2, 2008 Share Posted July 2, 2008 Founds something I figured all the Mopar guys would like. A company that makes bell housings for small block and big block Mopars. Main to I found interesting was Dodge to t 56 and t5. That now opens up manuals to mopars. Need to scroll down a ways to get to the Mopar stuff. http://www.safepay.net/cgi-bin/shop/cart.cgi?db=mddata.txt&category=bellhousing&merchant=moderndriveline Quote Link to comment Share on other sites More sharing options...
Magnum380Z Posted July 2, 2008 Share Posted July 2, 2008 good find! Quote Link to comment Share on other sites More sharing options...
Greg55_99 Posted July 18, 2008 Share Posted July 18, 2008 OK... http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=3168502&page=3&fpart=1&vc=1 Greg Quote Link to comment Share on other sites More sharing options...
