question for the big studs
Well how about head studs? I'm swapping the heads out on my SBC that is mounted in the JTR position can I remove the heads with out pulling the block if the motor has studs? ( it currantly has bolt but I'm thinking about installing studs from ARP) just wan't to know about the next time now? Has anybody else had this problem? Keith
rx7260z@yahoo.com
Speed Power Performance& Style. What else is there?
Guest Fast Frog
Yes you can. I switched a pair of 487 hds for a pair of Edelbrock aluminum hds. Just be sure you get the correct torque on the lower bolts/studs, particularily, on the drivers side. If you can remove the headers easy enough, it makes torquing the head much easier.
