need base fuel and timing maps
CantZme
anyone willing to share base fuel/timing maps for something along the lines of stock boost (7psi) L28et setup? I/c'ed, 437cc CFI ford inectors, 3in dp to exh. and everything else is pretty much stock. Running v2.2 with the flyback board and running ignition off the CAS. I want a base fuel map that I can hopefully improve on when I start tuning with the wideband and I want to get a good foundation. Any help is appreciated...and btw I searched.
the only map I found was the one you posted with your 8psi setup,which I was planning to use; however, I was hoping to possibly start with a tune from someone who had used a wideband. Nevertheless, thanks for your response and the installation write up as well, I would have never figured this Ms thing out by myself:wink:
