Guest Anonymous Posted June 6, 2002 Share Posted June 6, 2002 I have seen the front brake topic covered many times....Where can I get the spacer...I want to put the nissan 4 piston calipers on my 1972 Skyline. I have the rotors and the calipers I just need the spacer...Help Quote Link to comment Share on other sites More sharing options...
Owen Posted June 6, 2002 Share Posted June 6, 2002 Check out the ads in the back of Carboy ,etc. Owen Quote Link to comment Share on other sites More sharing options...
Guest scca Posted June 6, 2002 Share Posted June 6, 2002 if your talking using the Z32 calipers on a Z you will spend a LOT of $$$ rotor offset isnt good so you need a 2 piece rotor and the calipers need a real, i have skyline setup on my car and Mark ? here has the similar setup in 4 lug on his car.. while we both did it we would not do it again as it is not a cheap o way out Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 6, 2002 Share Posted June 6, 2002 Mike is right on with his coments. He is not just trying to sell you something. If you want bigger brakes go with a kit one of the guys on this board sells. If you pay someone to adapt those brakes to your car, you will spend more than the cost of one of these guys kits. I know because that's what I did. Mark Quote Link to comment Share on other sites More sharing options...
