Canadianz Posted May 20, 2007 Share Posted May 20, 2007 Alright folks, Ive hit a slight issue while setting up my new maninfold. I bought a KU Engineering intake manifold with a 90mm throttle body. However, the throttle body seems to have the wrong fitting for the stock Rb throttle position sensor (TPS). The Rb TPS has a peg that sticks out and fits into the throttle body. However as you can see the throttle boddy I have is the exact opposite as the throttle body has a peg that goes into the TPS. Ive fired off some e-mails to the boys at KU and Im awaiting a reply. Can anybody Identify which sensor this is ? I think it might be off a supra .. which also probably wouldn't interface with the stock rb ecu. Any how sorry for the Ramble, if anyone has any ideas as to how I can get the throttle body to work I would appreciate input. My intake, note the ring and peg sticking up for the TPS sensor, any idea of what sensor it takes ? This is the sensor I think fits mine . . . I belive its off a last gen supra ...not hundred percent though Any ideas ? thanks Quote Link to comment Share on other sites More sharing options...
bryan01 Posted May 20, 2007 Share Posted May 20, 2007 what rb TPS sensor do you have? my rb25 series 1 has a tps that has a hole in it that accepts the shaft that comes out of the throttle body. by the way, i got a q45 tb that came with a sensor on it that at least looks exactly like the rb sensor. it's even labeled nissan, bolts up the same, and has the same plug on it. if you want it i could send it to you and you could see if it works. Quote Link to comment Share on other sites More sharing options...
