MS files for new N/A install
Zmanco
I've gone through the stickies, but just about everything is for turbo apps. I'm going with the following: (hope to finish with the install this weekend and fire it up!)
MS1 v3.0
MSnS - Fuel only
L28 w/flat top pistons
stage III equiv cam
headers + exhaust
MSD 6AL w/280ZX dizzy
Stock '80 intake manifold
Stock turbo injectors
60 mm TB
Anyone have a map they think is close for me? I live at ~6500 feet, but don't think that should matter.
Also, FWIW, I'm going with the 2nd MAP sensor for real-time barometric correction. Also, modded the board for the electric fan control, and will be using a PWM idle valve from an early SAAB. I'm worried I've got too many non-standard things going on simultaneously. I may deactivate the idle valve if I have problems bringing things up from scratch.
Also, as the injectors are low impedance, any recommendations for a starting point for the PWM settings for TURBO injectors?
Z-ya suggests the following for the stock N/A injectors from post #9 in this thread:
http://forums.hybridz.org/showthread.php?t=121361
  z-ya said:
I measured an OEM NA injector that is fresh from being cleaned and flow tested, and the opening time is around 1.2ms.
For OEM NA injectors I would set the PWM as follows:
PWM time threshold: 1.5ms
PWM Current Limit: 35%
