Fuel Pump Issues with my 73' L28e
mk2mike
Okay I just picked up a 1973 with a L28 Swap on dual webers. The Previous Owner installed a little fuel pump in the engine bay replacing the mechanical.
It seems as if it's not drawing gas from the gas tank though... it's been sitting a while and I know it has gas but not drawing anything from there...
Im thinking of just installing an electric fuel pump in the rear of the car near the tank...
What fuel pump would you guys suggest for cheap to feed my L28 w/ dual webers??
BTW I ran a line from the fuel pump to a litttle 2 gallon gas tank and it runs off of that.. but hooked up to the main fuel line it doesn't seem too....
pic for views and maybe help
Try removing the line at the tank and blow some high pressure air thru it. If it were me I would reinstall a new mechanical pump, it will deliver the correct pressure and amount,and it's not electric...... one less thing to up and quit on you when least expected( that's just my take on things).
