OK did I do good or just waste $$$?
what thickness rotor are they for and what piston size..
IF they are 1.88" as most late model dirt are or larger they wont work on a Z the pedal will hit hte firewall before the car stops
are you sure 1.25" thats awfully small....
generally i use 1.75/1.62" taper for fronts and i know that the common dirt setup is 1.88/1.75 and sprint cars go over 2"
i think that is almost too small for the fronts. measure them to see -
those must have been rear calipers or they used a extremely small master.
i have rotor adapters here for that and rotors as well and brackets but i still think the pistons are too small... pedal will be super firm though! tongue.gif
Hey mike they are 1.25 1.25 pistons but he said he will buy them back if I buy the 1.75 1.62 from him new I did not pay much so I think ebay may be the best way to unload them How much for a set of parts for coil overs for my 280z tubes I can only afford to do the fronts now also can I get your input on the mods I should do to the tubes? I have cut the lower perch and that is about it. Keith
