Dan Juday Posted June 12, 2002 Share Posted June 12, 2002 Got Flares? I'm running 265/50/15's up front on 8" rims. But I've got coilovers and SubtleZ fenders, about 2" wider than stock. Just barely fits. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 12, 2002 Share Posted June 12, 2002 ... for the front? And what about about 295/50HR15's for the rear? I picked up a sweet set of rims and need some new tires. Has anyone ever gone this BIG! If not, let me be the first. *Wow those tires are huge! (thats what all the ladies will be say'n) * Sorry, I was day dream'n. So, has anyone tried super wide tires yet. I can get a set of Kumho's for the rear and Nitto drags for the front. **I have friends in all the right places Nic Oh, I'm running 15x9's and 15x10's. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted June 12, 2002 Share Posted June 12, 2002 I have 295-15-50s on 10" rims, but to get it inside the stock rear quarter, I had to mini tub the wheel wells and add a shortened 12 bolt Chevy diff. You can use them with really wide flares. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 12, 2002 Share Posted June 12, 2002 Ok. Yes, I've got flares About 3" in front and 4" in back. I was just unsure if it would be drivable. Oh, I too have coils. Thankx, Nic Quote Link to comment Share on other sites More sharing options...
PaulR Posted June 12, 2002 Share Posted June 12, 2002 Just for another data-point, here's what I am running: FRONT: wheels: 17x9 tires: 245-45-17 coilovers: yes, 10" free length flares: no comments: no rubbing at full bump and/or lock REAR: wheels: 17x10.5 tires: 275-40-17 coilovers: yes, 10" free length flares: yes, 1.75 inch (MSA "street flares") comments: no rubbing at full bump I don't think I could go any bigger in front without flares. In the back, I think 295's would fit. Therefore, you should be able to get those tires to fit given you have OPTIMIZED OFFSET . Also, be warned, parking lot manuevers were a B*TCH before I added power steering Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted June 13, 2002 Share Posted June 13, 2002 Can't give any insight on how it will drive. But the rears will fit no problem with 4" flares. I'm running 305/50/15's in the back with 4" flares. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 13, 2002 Share Posted June 13, 2002 Bad bad news. I put the fronts on and they fit, well if I plan to only drive forward and never turn. The front of the tires rub on the fender lip. I'm planning to swap the fenders out and put on my glass racing fenders. I'm just upset I have to work more to make this thing fit. Thank you all for the tips. I hope I can get this to work. Oh, the backset is around 3.5" (from the inner lip to mounting face). I have A LOT of clearance behind the wheels. Nic Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted June 13, 2002 Share Posted June 13, 2002 The backspacing is your problem Nic. I tried some rims off a Tomahawk that had that backspacing and 265/50/15's. Same problem. The rims I ordered are 4 3/4". If I had to do it again though, I'd go with 4 1/2". I figured I'd err on the side of too much. I can always add spacers. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 13, 2002 Share Posted June 13, 2002 Well, What do you suggest I do? I found a company that will change offsets. I'm not sure how much it would cost. I'll write to them and find out. I'll let you know how much it is, otherwise would it be better to cut the fenders to fit or replace the wheels? Nic Quote Link to comment Share on other sites More sharing options...
