cygnusx1 Posted May 27, 2007 Share Posted May 27, 2007 I am finished wiring the MS-II. I have not yet attempted to start the car. I wired it all according to the manual and the DIY page about wiring to the 83 Turbo Distributor with the 1K pull down resistor and the board modifications. I followed Mobythevans procedure about turning back the crank pulley to about 50-60degrees BTDC. Then I loosened the distributor bolts and rotated it back and forth within the timing adjust slots. I did not get any lights to come on on the MS-II box. I am tempted to just crank it over....any further advice? Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted May 27, 2007 Author Share Posted May 27, 2007 NEVERMIND! I decided to turn the key and I discovered that I had not hooked up the fuel pump relay to the ign key.....doh. I connected it and the motor fired right up first crank for about 2 seconds. Just in case someone stumbles upon this thread: The ONLY thing I needed to adjust was the TRIGGER ANGLE parameter in Megatune. I just kept increasing and decreasing the trigger angle numbers until Megatune read the same as my timing light. Quote Link to comment Share on other sites More sharing options...
