HICKL Posted May 29, 2007 Share Posted May 29, 2007 OK, I picked up some 8" wide draglites with a 5" offset. They came with some 11.5 wide cheater slicks. Only problem is I have to run a 1/4 spacer to keep them from rubbing on the strut tower. I will get longer wheel studs. This being said, is there a real safety issue with running wheel spacers if eveything is done right? Thanks Jeff Quote Link to comment Share on other sites More sharing options...
jt1 Posted May 29, 2007 Share Posted May 29, 2007 If the spacers are made of quality material and fit properly, and the studs and nuts are upgraded, I don't think they present a problem at all. Usually the people who have trouble with spacers have some cobbled together mess. John Quote Link to comment Share on other sites More sharing options...
Shift Posted May 30, 2007 Share Posted May 30, 2007 hub centric ring. Quote Link to comment Share on other sites More sharing options...
MY77Z Posted May 30, 2007 Share Posted May 30, 2007 jeff, did you roll your inner fenders lips? and BTW, where to get some high quality spacers? Quote Link to comment Share on other sites More sharing options...
HICKL Posted May 30, 2007 Author Share Posted May 30, 2007 jeff, did you roll your inner fenders lips? and BTW, where to get some high quality spacers? I have done no more than bolt the wheels on. I need to do something as those tires are pretty wide. I may end up going with a narrower tire. Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted May 30, 2007 Share Posted May 30, 2007 These cars are not hub centric... That will be a waste of money...We have people running cheap spacers like the one your using making over 800hp and pulling the front end a few feet off the ground... Just do not go very thick.. Quote Link to comment Share on other sites More sharing options...
HICKL Posted May 30, 2007 Author Share Posted May 30, 2007 I have 1/4" thick ones in there now with room to spare. Quote Link to comment Share on other sites More sharing options...
