Fuel Delivery Problem Solved
A while back I wrote about a situation i was having where the car would just act like it was running out of fuel and would just stop runnint. You could hear the pump run (at times) and at times it would not, but either way there would be no fuel to carb.
I had a lot of work done on car to engine over the winter, so I thought maybe this was causing pump to lose its' prime. what I did that seemd to cure things was to relocate the pickup line from the original 240Z spot to the drain plug hole. Now there is plenty of fuel flowing to carb and car runs great. I figure that with the extra power from the engine this location better feds fuel to pump since it is lowest point on tank and gravity adds the extra bump.
