Vacuum Gauge Connection ?Signal quality?
This question and answers will be applied to my 74 260 406/th400 street/strip car but for now apply to my 67 Chevelle 454/th400 with a Holley 780 VS. I'm Installing a vacuum for carb tuning purposes among other benefits.
Route separately or tie into existing vacuum line? That is the question.
A clean and easy install would be tapping into the steel brake vacuum line adjacent to the firewall and prior to the vacuum canister.
Would the vacuum signal be a little slow/lazy or moderated by the larger [1/2†vs. 1/8†or 1/4â€] diameter line?
As proposed would applying the brake affect the vacuum signal to the gauge? Don’t want that.
I want to monitor engine/manifold vacuum not brake line vacuum.
Is the vacuum signal to a gauge unaffected by other connections along the same line?
THANKS in advance.
Guest VietVet
You referred to tapping into the vacuum line going to the Brake Vacuum Canister.
Most cars have a one way valve in that line. Do not - Do not tap the line between the check valve and the canister.
Better to have a little longer line and tap closest to the intake manifold.
Hope this helps.
Newbie on this site. Old School Z-Car pilot.
Cheers VietVet :) - :)
AKA VietVet68 AKA AmyCroft on www.my350z.com see my totaled 350Z
http://www.my350z.com/forum/showthread.php?s=&threadid=86865
The Vanity Plates have been moved to the 1988 300ZXT Shiro Special.
But it's not the same as on the 350Z Puz Z
( I thought I'd get a G35 Coupe and use the plates - but the G35 guy's
have little or no sense of humor. :) )
THANKS in advance.
