Yorgee Posted June 10, 2007 Share Posted June 10, 2007 http://page.auctions.yahoo.co.jp/jp/auction/95583899 I saw this auction on yahoo japan while I was searching for fender mirrors. Is that done for higher compression or something? It would be hard to weld everything evenly to have the compression the same in every cylinder. That is if that is what they were trying to accomplish. Anyone have any ideas or seen this before?? Quote Link to comment Share on other sites More sharing options...
NCchris Posted June 10, 2007 Share Posted June 10, 2007 Welding combustion chambers was done quite a bit back in the day to reshape combustion chamber profile, modify squish, adjust compression ratio on race engines. The "How to Modify Datsun & Nissan OHC Engines" book touches on this. Welding can also be used for repair. Others may want to chime in with more specific info. chris Quote Link to comment Share on other sites More sharing options...
BlackBeaut Posted June 10, 2007 Share Posted June 10, 2007 Eurk!! Clearly a work in progress, they could've at least cleaned it first before slopping the weld in there! Compared to some of the works of art that appear on yahoo japan this one wouldn't even get the job of janitor at an art gallery! Cheers, Rob Quote Link to comment Share on other sites More sharing options...
Yorgee Posted June 10, 2007 Author Share Posted June 10, 2007 Thanks for the info chris, first time I've ever seen something like that but I guess it makes sense. And I agree with you rob, it's not the prettiest mod. Yahoo japan usually has some high quality parts. But I guess someone with some experience could turn that work in progress into a work of art as well. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted June 10, 2007 Administrators Share Posted June 10, 2007 Functionally, that weld job is fine, granted, cleaning the area to be welded prior, such as bead blasting woud be prudent. The welds on this particular head pictured below looked about the same prior to us reshaping the chambers and decking the head, though we bead blasted the head prior to welding. The only real difference between this one and the Japanses head in the ad is this head had more material added around the spark bolt boss. Quote Link to comment Share on other sites More sharing options...
