SF Machine Shop recommendation
datz280
Hello all,
I have just brought home an 82 turbo to put in my 77 ;). I am looking for a shop in the SF bay area to do a rebuild. All I am looking for is a basic rebuild, someone who will check the cylinder bores, flatness of the head and block, and make sure the crank is straight and give it a polish. The only upgrade to the internals I am looking for is shot peening the rods, instilling forged pistons, and balancing the rotating assembly and reassemble with ARP hardware.
The only place that would talk to me was Rebello. Labor was going to be in the $800 range. I would need to supply the bearings, pistons, head gasket, etc.
My goal is to upgrade the fuel rail and injectors, use the hy35 holset, and mega squirt and spark. In the future I would plan on changing the cam to the Isky some people are using.
I have not seen any posts recommending a machine shop (I saw the body shop referral list) Any recommendations on a shop that you know of or have used that is clean and competent in the area would be appreciated.
Mike
I've been using Rob's machine shop in Hayward on a few L16-L18 engines and also had some head work done on various datsun motors and my toyota 4 Runner heads. They do really good work, and can build/do what ever you want from cheap and simple to complicated.
