Strange Starting Problem
Yoak
Hey Gang,
I have been having a very strange starting issue with my 79ZXR for awhile now, and I simply can't figure out what is causing it.
The car for the most part will start right up, but on occasions the car will need to be cranked for a good while and it will rumble around 500 rpms and die....if you give it some gas while it is at this point it will usually start right up.
If you don't get the car to start within a few times of it rumbling...you will have to turn the key to the off position and try a few times...it simply will not start....
I have done allot of replacement work on the car, and I will list them below.
One other note that could be related. When driving the car runs very cool for the most part, there are no issues with overheating. However, when I turn the car off and let it set, the temperature will jump considerably....
My 240z, does not have this issue...
In an effort to replace all dieing parts here is what I have done.
New Radiator
New AFM
New TPS
New Cold Start Injector
New Thermotime Switch
New Temprature Sensor
New Blaster Coil
New Plug/Wires
New Distributor
New Air Bypass valve
New EGR
New Fuel Pressure Regulator
New Radiator Cap
New Injectors
Added Rising Rate Fuel Pressure Regulator
New Water Pump
New Fan Clutch
New Injector Clips
New PCV Valve + Host
Replaced Vacume Hoses
Pretty much everything you can think of I Have replaced, and there is a noticeable difference in mpgs, and car performance...
One final note is that as the afm is adjusted richer, the car has more trouble starting....the car is already running pretty lean
I will have to install a fuel pressure gauge, buy on the return line it shows around 40 psi, but I honestly don't entirely trust that gauge.
My car did not come equiped with the auxillary cooling fan.
