Guest ckoontz Posted June 25, 2007 Share Posted June 25, 2007 I tested the resistance between connectors 6 and 8 it reads 200, where as it should be 180ohms. Likewise connectors 8 and 9 reads 111 when it should be 100. Is there anyway that I can make adjustments, so the resistance is correct. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted June 26, 2007 Administrators Share Posted June 26, 2007 In most cases, you should be adjusting it to run the car properly, with little regard for 'book resistance'. I bet if you spend some time searching, you'll find a good deal of info regarding adjusting AFM's. Quote Link to comment Share on other sites More sharing options...
