RB25DET cam sensor problem
triple B
Well my Z31 RB25 swap is going well i have a spare cross member i am modifying to get the motor mounted up after i pull the VG this sunday:mrgreen:
i am tearing down the RB right now and i am havin problems getting the cam sensor off the timing cover
are there more than 3 bolts hodling it on
i see where it looks like there might be 3 screws on the end the sensor but they have no heads so i thought they were guide pegs
i can't locate my thumb drive with my service manual on it at present so any input or suggestions would be helpful as this is the only thing holding up the teardown
yeah both are on the to buy list for parts.
i am lookin for cams to. the HKS and Tomei ones are pricy but the only ones i have been able to find
pistons and rods are no problem just have to decide between .020" or .040" over. and i was going ferrea for the valve train
upgrading to a gt35r turbo as well :mrgreen:
already have the RB20 oil pan from a 200ZR and the greddy intake manifold
oh and at least a 1.5mm headgasket
nice.
25psi on a 35r should be in the 560rwhp ball park, give or take depending on tune. that's a friend of mine's set up on an aem ems.
i'd like to sell my power fc and get an aem myself. all my internals are stock cept a commetic 1.2mm and arp head studs. i don't really want to take my t belt off again to put my n1 water pump on but as it gets hotter and hotter outside i might have to. my friend with the 35r uses his in an s13 drift car he's actually thinking of going gt30/71 instead.
i'm not sure what mm was in my other rb25 before the t belt broke but compression across the board was 135psi. my new one stock was 170ish, first thing i did was tear it down and put the 1.2mm in there so now it's 145ish, which makes me think the first one had maybe a 1.4mm
if i was you i'd prolly go .020 first, just in case, so if you need it machined again then you can go .040, instead of .040 off the rip, then if it breaks you need a whole new block or a resleave.
anywho goodluck with it, sounds like you're definately on the right path. take care
Dave
