will this combination work together?
Guest forsc
Guest forsc
Hi everybody, I've been trying to find an answer in the previous posts but no luck.
Here goes...I have a 350 TBI engine from a '93 GMC pickup, and I have a line on a T56 from a '99 Z28. Will this combination work together?
Will the '99 trans bolt up to the '93 350?
Will the '93 engine be able to use the JTR engine mount setup?
Also, are there any electronics on the '99 T56 trans, the wiring and PCM I have came from a '90 caprice with a 350TBI.
Any help offered would be greatly appreciated....B4 I go spend $1000 for the rebulit trans......
Thanks
Chris
it will work but you will have to buy a converision kit, bell housing, clutch master and slave cylinder
your best bet is to use a 93-97 f-body t56 then you just used the stock stuff and mount the master and slave
