Headlights stuck on high beam.
Argle bargle.
So, unfortunately, I got into a wreck in my S130 on July 4th (and yes, i was freakin' sober not even a sip of booze. The roads were extremely wet and well... lets just say apparently gone unnoticed.... there was a patch on my tire inside that was as soft as a baby's bottom and i hydroplaned into a wall.) :cry:
it damaged the front right of the car; knocking my bumper to the left (driver side) and even denting my hood as well as destroying that 1/4 panel above the wheel. My headlight as well as the headlight cowl were destroyed, and i eventually just removed the 1/4 panel, headlight fixture and replaced teh headlight itself. Mind you, my car is still smashed inward a bit, i mechanic-wired up the headlight so it wouldn't wobble around and i could have a 2nd light while driving at night;
But, the lamp only comes on slightly, and my headlights are stuck on highbeam; the switch doesn't turn it on or off anymore just stays on. My driver lamp works fine, but the passenger, even after a new lamp is still barely lit. I couldn't see any damage to the pig-tails (connector).
Has ANYONE ever experienced this before and could give an idea of where the hell to look?
(not to mention this happened two days after i bought the turbo, ex. mani, downpipe and return line for the ZX :-( but is still in a tub on my porch)
