twistex Posted July 31, 2007 Share Posted July 31, 2007 ok i have a 1975 280z wth a 1983 280zxt motor. harness computer maf all that is from 83. the 280zxt i had running perfect before removal. i wired everything up as far as the sticky says. coil ignitor contants switched start signals fuel pump relay yada yada yada. anyways when i pull the coil wire off the cap and put it next to some metal to see it send sparks as i crank it. it only sparks 1 time per second or like revolutions. it should sprak every time the rotor passes the cap on each of the 6 cyl. i dont know whats going on . and when i go from ignition on to off it sends a spark. anyone know why it could be doing this ? Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted August 13, 2007 Share Posted August 13, 2007 This is normal. You had just verified that your crank angle sensor still working. Quote Link to comment Share on other sites More sharing options...
