how to degree in a cam
youll need a few basic tools and a good understanding of what your doing, but its certainly not all that difficult.
I was asked where to get a CHEAP degree wheel
heres one you can print out and save for engine builds on the engine stand
(put curser on an click)
http://savetheledges.org/test/AVS/images/tech/CrankDegreeWheel.png
KINKOS can print this and laminate it in a 18" dia.
you could buy these from summit racing or similar parts from jegs
http://www.summitracing.com/
http://www.jegs.com/webapp/wcs/store...10001_10002...
MOR-62191 $44 (wheel)
MOR-61755 $47 (SBC)
MOR-61756 $47.(BBC)crank sockets
SUM-900188 $17 (piston stop, head off)
SUM-900189 $6.95(piston stop, head on)
TFS-90000 $94.95 (degree kit)
youll also want two flat tappet solid lifters and two weak check springs
instructions
http://www.iskycams.com/camshaft.html
http://www.thedirtforum.com/degree.htm
http://www.ridgenet.net/~biesiade/camdegree.htm
http://www.hotrodder.com/kwkride/degree.html
http://www.cranecams.com/pdf/803.pdf
