Series one 240Z
You have to replace the innards of the tach. Might want to switch from an ampmeter to a voltmeter.
Plus you really should relocate the rear diff if it is one of the early cars with the foward mounted diff. Upgrade to an R200 in the process. That means new mustache bar, new rear crossmember and flip the front diff mount. You will already be replacing the driveshaft.
The series one cars have the fuel lines routed through the tunnel. Not sure if the later cars changed that.
Yeah, it bolts in. There is a list of required parts in the following link
http://forums.hybridz.org/showthread.php?t=116207
Nissan changed the tranmission mounting ears somewhere along the way. Don't worry about it. For the T56 to fit you will most likely have to cut them away and maybe hammer out the tunnel for a bit more clearance. Nothing to fret about.
