zkoresko Posted August 8, 2007 Share Posted August 8, 2007 Is there anything different about installing a LSI/T56 in a series one car vs a series two car? The only difference I know of is the center console has to be replaced with a series 2 center console. Is there anything else? Quote Link to comment Share on other sites More sharing options...
piston Posted August 8, 2007 Share Posted August 8, 2007 trans tunnel from the 240z is different from the newer 280z... Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 8, 2007 Share Posted August 8, 2007 You have to replace the innards of the tach. Might want to switch from an ampmeter to a voltmeter. Plus you really should relocate the rear diff if it is one of the early cars with the foward mounted diff. Upgrade to an R200 in the process. That means new mustache bar, new rear crossmember and flip the front diff mount. You will already be replacing the driveshaft. The series one cars have the fuel lines routed through the tunnel. Not sure if the later cars changed that. Quote Link to comment Share on other sites More sharing options...
zkoresko Posted August 9, 2007 Author Share Posted August 9, 2007 For relocating the rear differential and switching to a R200 - will all of the parts from a 280Z bolt right up or are the holes in different locations? Quote Link to comment Share on other sites More sharing options...
zkoresko Posted August 9, 2007 Author Share Posted August 9, 2007 piston said: trans tunnel from the 240z is different from the newer 280z... How is it different??? Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 9, 2007 Share Posted August 9, 2007 Yeah, it bolts in. There is a list of required parts in the following link http://forums.hybridz.org/showthread.php?t=116207 Nissan changed the tranmission mounting ears somewhere along the way. Don't worry about it. For the T56 to fit you will most likely have to cut them away and maybe hammer out the tunnel for a bit more clearance. Nothing to fret about. Quote Link to comment Share on other sites More sharing options...
