vrocious Posted August 11, 2007 Share Posted August 11, 2007 i am at my wits end as i have spent the best part of 2 days ripping the car apart trying to find the problem and fixing others as i see them. My cruise control wont enguage, i can turn it on and the unit powers up fine displaying the on light but when i press the button on the stalk nothing. I've checked the relays and tried putting others in but that didnt do anything, i pulled the cc control panel out and that seems fine as i sprayed it with contact cleaner and replaced all the globes while i was at it. wiring harness and plugs (as far as i can see without ripping the dash out) are fine, tried getting into the stalk but the screw is so brittle it started stripping so got in as best i could and cleaned it out and when that didnt work just unplugged it and made a bypass relay from the plug but to no avail. as far as i can tell all the vacuum hoses are in the right plugs (my haynes manual is american for lhd and i'm in oz with a rhd) plus all this turbo components throws me off a bit. can somebody please shed some light and help me? Quote Link to comment Share on other sites More sharing options...
nbesheer Posted August 11, 2007 Share Posted August 11, 2007 Do you have an after market speedometer ? Because if you change it then the CC won't work. Quote Link to comment Share on other sites More sharing options...
vrocious Posted August 11, 2007 Author Share Posted August 11, 2007 nope as far as i know it's factory does not look any different at all Quote Link to comment Share on other sites More sharing options...
