o2 sensor wiring
olie05
I made the mistake of getting a 4 wire o2 sensor from a 92 or maybe 93 ford thunderbird at the JY. I'm pretty sure it was a v8 and I pulled the passengers side pre-cat one.
I am confused as to which wires are the heater wires and which wires are the signal wires.
The colors I have on the hanress are:
gray with yellow stripe
gray with red stripe
Black with green stripe
tan with orange stripe
can someone please tell me what these do?
Just from a general wiring point of view, I would surmise that your two grays are the heater, the black is ground the and tan is the sensor. You could always use a multimeter and ohm out the wires to see which ones are the heater. They will more than likely read little to no resistance as it's a heating coil. Usually those coils will increase resistance as it heats.
