Guest Pegasus76 Posted September 9, 2002 Share Posted September 9, 2002 Hey guys, was just wondering if anyone has or knows where I can find aftermarket driveshafts for my 350 SBC. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 9, 2002 Share Posted September 9, 2002 I do not know if you can find an off the shelf aftermarket GM type driveshaft in the specific length of your 350 SBC application except JTR or MSA since the length varies according to tranny.I would imagine that somewhere there are places that you can custom order a drive shaft to your specifications which is probably where some of the driveline shops get theirs. I bought a ($10.00 with new u joints) Corvette aluminum drive shaft on speculation that it could be shortened. My search so far for a shop reveals that this cannot be done anywhere professionally in Oregon and somwhere in California or maybe a shop in Seattle. BUT they can all order me a driveshaft for $300.00 plus,,so some where driveshafts are being made.I will do further search. Any one want to buy a lightweight Corvette shaft ? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 9, 2002 Share Posted September 9, 2002 Use a Chevrolet a shortened and re-balanced drive shaft with GM u-joints with a Neapco # 2-2-899-1 adapter flange that wiil adapt the GM drive shaft u joints to the Darsun R 200 differential which all will handle a 350 SBC power easily. I can obtain the adapter flange locally for $32.74 I got quotes all the way to $41.20 on this flange adapter. Apparently there is another adapter # 2-2-899 (without -1) that is not the right one.You just may not find a bolt in out of the junkyard because I never heard of any one locating one. Drive Line Northwest (1-800-552-7647) will shorten ad balance my Corvette aluminum drive shaft for $125.00 which is about $75.00 less than a local shop will shorten a sreel GM drive shaft. Shop around and get a good deal. Quote Link to comment Share on other sites More sharing options...
jaime240z Posted September 9, 2002 Share Posted September 9, 2002 Tomahawk, where did you find the neapco adaptor for that price? I'd like to get one and I'm looking to save as much $ as possible. I know JTR sells it for 50 bucks but if I can find one for less that would be sweet. Thanks! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 10, 2002 Share Posted September 10, 2002 Jamie $32.74 at J Thorpe Enterprises / Drive Line Shop on 29522 Airport Road in Eugene Oregon Phone:541-607-3610 I do not know what the shipping would do for the price. He said he had two on the shelf. Cheapest quote out of the 3 I called of the four shops in this area Quote Link to comment Share on other sites More sharing options...
jaime240z Posted September 10, 2002 Share Posted September 10, 2002 Sweet. Thanks Tomahawk. It just dawned on me that Concord Driveline Serv. is on the way to work for me. I bet they can get it for me. I'm going to stop by there tomorrow. If not I'm calling Ore. Thanks again! Quote Link to comment Share on other sites More sharing options...
Guest Pegasus76 Posted September 10, 2002 Share Posted September 10, 2002 Hmmmm, thanks for the insight Tomahawk. I was always wondering if you can somehow buy a driveshaft which would withstand the power of the 350 without having to swap out the axle...But I suppose it would be cheaper just to get a new axle from a junkyard or something and clean it up and install hahaha What would be the best Axle to search for? Quote Link to comment Share on other sites More sharing options...
