How to reach 280z expansion valve
My A/C doesn't work, and it was recommended I replace the dryer as well as the expansion valve, the valve I know is corroded shut, and the dryer is probably dead anyways. The dryer is easy to access, but i don't know how to get to the expansion valve. I know it sits behind the vent panel/air control panel, but I don't know how to reach. Any help as to how to get the panel off and remove the valve?
Thanks
You need to pull the dash and then you can remove the box that the Evap core & expansion valve sit in. I'm currently going through my A/C stuff, so I may retro fit something newer there for the Evap core, as everything else will be newer R134 stuff. I'm assuming that you already had a place evacuate your system? Make sure you have the system fully evacuated to get out all moisture before adding refridgerant and make sure to add oil and leak dye to the system.
