olie05 Posted August 28, 2007 Share Posted August 28, 2007 I have searched for hours... thinking, Surely this topic would have come up at some point. I would like to know what size the nuts are on the two front differential mount bolts. These are the two bolts that go through the two holes in the front of the differential and attach it to the rubber isolator. I purchased a set of m10x1.5 and m10x1.25, but the correct size is M12. Now, before I go and buy m12x 1.25,1.5 and 1.75, I was hoping someone would know exactly what the pitch is supposed to be. also, it would be nice if there was some directory of bolt sizes. Just a thought. Quote Link to comment Share on other sites More sharing options...
olie05 Posted August 29, 2007 Author Share Posted August 29, 2007 bump... anyone know? Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 29, 2007 Share Posted August 29, 2007 Just buy nuts at the same time you buy the bolts and it won't matter. You can even get some nylon lock nuts. Quote Link to comment Share on other sites More sharing options...
MrFancypants Posted August 29, 2007 Share Posted August 29, 2007 Cant remember for certain if they are coarse or fine, but I would wager they are fine thread. Nissan doesnt seem to like using coarse threads much. The easiest solution is to get both nuts and bolts at the same time, but I would guess they are M12x1.25. If you want to be certain, compare them to your lug nuts/bolts. - Greg - Quote Link to comment Share on other sites More sharing options...
