having some troubles
280tyler
today i was working on getting my car started i'm running ms1 v3 fuel only code and msd 6al for spark the first thing that tripped me up was i was not getting a tach signal i had the tach wire hooked up to the the output on my 6al i messed with it for a little bit the i decided to re jumper the reversed Zener diode to see if i could get a signal that worked will it hurt any thing to try and run it like that? i hope not
after i jumped that i tried to start it and it acts like it wants to start as soon as i press the starter button it fires and then dies it only fires for 1-2 secs. i tried messing with it for a wile i fouled the plugs 1 or 2 times. setting hear thinking about it my thoughts are that i could have put the dizzy shaft 180 out or that diode/jumper could messing with it
any info would help thanks
