converting to turbo using l20et parts
vrocious
is it possible to turn my n/a l28 into a turbo using donor parts from a l20et? had a look around and couldnt really find anything on it. would it be possble to get the necessary internals and injectors off it and bolt on to the l28 or are piston sizes etc different, so not just stroke that makes the difference in displacement on these motors.
you can do this easly. but its best to get the l20et loom/ecu/dizzy/afm and dizzy oil pump drive. Replace all this gear on the l28, find some vg30et injectors (270cc) and run from there, Should be pretty pepy. the small turbo off the l20et will give instant response on the l28. But will run out of breath easly :(
