LT1 with a th350?
The TH350 will bolt right up with no changes.
Edit: You might need to create some sort of vehicle speed sensor (VSS) to feed to the PCM so it can manage the IAC. If your TH350 has an electronic speedo connection that is all you need.
Without the VSS you may run into issues with the engine stalling when you come to a stop. I had this problem with my LT1/T5 combo until I cobbled together a VSS.
Wheelman
