head swap
niner11
Been searching but I can't seem to find out what to do with cam timing when swaping heads.
I have a 280zxt with a p90a and before removing the head I found TDC on number one and marked both links of the timing chain and sprocket. Well as soon as the head came off I noticed my #2 exh valve was pretty damaged. I don't feel like putting any money into this head so either one of my p79's or another p90 will go back on.
Here is my question: When putting a different head or a different model head (p90a to a p79 for example) back on this motor is it all the same as long as I put the same sprocket on a different head? Just line up the marked links and use the #1 hole as before. Thanks, I imagine it is the same but never heard anyone discuss it.
Thanks, I made a wooden timing chain holder from what a few other posters had described. I think it start at about 1.25 inches wide and tapers into a "V"
Might not want to create new MSII maps for the higher compression head so probably going the P90 route..again
