Yay!!!
Racinjitter
  • 6 months later...
ok about the map in this zip file. The +5 with notes is the same file as the +5, it just has a few notes about sensors/mods I have on the car. The +5 means that I added 5% more fuel overall to the original base map. The ECT fixed map is the updated map for the correct factory ect sensor. I noticed that it was about 5*C from the IAT after a cold over night soak, so I adjusted it accordingly. The ignition lock timing set map is for setting the base timing and it turns off the injectors so that it does not start. To set the timing you may need two people, one to crank the engine, one to read the timing light and turn the CAS. The Jason ritter IAT map has the GM IAT curve in it and running correctly. I made this just to verify that it was working properly. Finally the stock rb25det map is the base map that was sent in the v500 when I recieved it.
Stock RB25DET Map(Racinjitter).zip
