Guest Dan [Sac] Posted September 24, 2007 Share Posted September 24, 2007 Couldn't locate one on their website. Is the other one (Adlashwa) worth the cash? I can work my way around oddball things (got one Probe GT RWD conversion already in the works with a 3rd gen RX7 rear subframe/susp) - are there some die-hard secrets to be found in some of the manuals floating around? The LS1/M6 that I was going to put in the Probe will call a Z32 home and I'll finish the Probe with its original Mazda V6 engine turned sideways. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted September 24, 2007 Share Posted September 24, 2007 Dont believe there are any manuals for that swap. However, I believe it has been done before and discussed here, so do a search and see if you can hook up with that person. Good luck. BTW, very interesting what you have done to the Probe. Since the Probe is FWD and the FD suspension is RWD, is the Probe now AWD? Quote Link to comment Share on other sites More sharing options...
Guest Dan [Sac] Posted September 25, 2007 Share Posted September 25, 2007 No, it's going to be RWD as the front hubs now sit sans axles. Transmission adapter and using an FC 5-speed gearbox to make the drivetrain compatible (the FC driveshaft bolts right up to the FD pumpkin). I saw Vann's site, looks like a very clean swap. I'll have to ask him why he went with the LSx master & slave cylinders instead of keeping the nissan units... Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted September 25, 2007 Share Posted September 25, 2007 That Adlashwa guy hasn't posted here for ages. I doubt that manual even existes anymore. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted September 25, 2007 Share Posted September 25, 2007 ;808878'].....using an FC 5-speed gearbox to make the drivetrain compatible (the FC driveshaft bolts right up to the FD pumpkin). Ahh, the missing bit of detail Quote Link to comment Share on other sites More sharing options...
JMT-Z Posted September 26, 2007 Share Posted September 26, 2007 Yeah I havent seen that guy around in some time.....Every LS1/Z32 swap I have seen so far is completely different than the next on how they did it. My opinion is just have a go at it yourself, you dont need a manual. edit: apparently this guy is planning on making a kit. http://forums.hybridz.org/showthread.php?t=121463 Quote Link to comment Share on other sites More sharing options...
