280Z Racer Posted September 24, 2007 Share Posted September 24, 2007 My car won't start it was last started 8 mouths ago, I have spark and fuel. so I checked to see if the fuel pump was coming on and it's not so I ran a hot wire to it and it comes on but it will not come on with the key so what is it? then I checked the fuel injecktor to see if they had signal with a Diod light and nuthing so WTF is it. plaes help me everyone. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted September 25, 2007 Share Posted September 25, 2007 from personal experience you might want to check the efi relay under the dash on the drivers side right next to the hood popper Quote Link to comment Share on other sites More sharing options...
280Z Racer Posted September 25, 2007 Author Share Posted September 25, 2007 What happend to you? did the EFI relay just go bad? Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted September 25, 2007 Share Posted September 25, 2007 a lot of issues are usually grounding for me at least.my ignition relay had a bad ground, and it failed to do anything because of it. i replaced the wire (because the one it had was totally shot) and that instantly fixed the problem. I also had a problem with my fuseable links being corroded, i cleaned all the contacts, and that fixed that problem. My TPS had corroded wires, cleaned them, problem fixed. so far almost every problem has been a grounding issue. right now i think i have an issue with my dizzy cap and coolant. check all the wires for corrosion. Quote Link to comment Share on other sites More sharing options...
280Z Racer Posted September 25, 2007 Author Share Posted September 25, 2007 Ok got it, Ill do that in the morning. Quote Link to comment Share on other sites More sharing options...
280Z Racer Posted September 25, 2007 Author Share Posted September 25, 2007 How do I test to see if the ECU is geting power? Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted September 26, 2007 Share Posted September 26, 2007 280Z Racer said: What happend to you? did the EFI relay just go bad? well, i ended up having bigger problems than the $100 relay. after replacing everything but the actually wiring to the fuel pump, i finally just hot wired my fuel pump to a switch and bypassed all of the above. works great and is great for theft protection considering i go to school in the straight hood Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted September 27, 2007 Share Posted September 27, 2007 I have a wire with alligator clips that run under the floor mat to the wires for the pump. one of the p/o's must've bypassed it for one reason or another. It just clips to the fuse box. The relay for mine works fine, so in my case as well, theft protection haha. Quote Link to comment Share on other sites More sharing options...
280Z Racer Posted September 27, 2007 Author Share Posted September 27, 2007 Ok fixed it, I clened the ignition relay ground and replace the EFI relay and renewed the the connection at the battery, then she fired right up. Done Quote Link to comment Share on other sites More sharing options...
zmaster Posted November 2, 2007 Share Posted November 2, 2007 I didn't want to pay a 100 dollars for a relay either so i now have theft protection, and a working fuel pump. Quote Link to comment Share on other sites More sharing options...
