Code version
midnightzxt
If you were going to upgrade code you might as well go to the newest stable release. Last time I looked that was like 029y4 or similar. You may need to re-tune because of bugs that were fixed in the code equations. Just go through every menu and check over every setting when you upgrade and you should be good. There are a lot of neat features in the newest code that give many more options for cold start tuning, accel tuning and many other things.
after much pain and suffering (config errors), I upgraded to the latest. The advance table import what screwing up the megasquirt some how. It's running great with some additional settings.
When I rev the engine is does so with flying colors except when I punch the throttle to the floor.. it chokes for a .5 sec and then revs up. I'll work on that.
