Guest Anonymous Posted April 11, 2001 Share Posted April 11, 2001 Hey everyone, I have a few question for you V-8 Z owners. The first question is about the cam selection for my 1995 LT-1 which I am putting into my 280Z. Can anyone recommend a good cam for this engine? Also has anyone used an aftermarket wiring harness and if so, what kind? Any information will help me greatly. Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted April 12, 2001 Share Posted April 12, 2001 what do you want for power/manners? stock cam with 1.6rr's/swapped head gasket/headers etc pumps up nicely all on its own. Next step is a 211/219 LPE cam which is v. well liked on the LT1 or a ZZ4 cam (mix your rockers/1.6 intake/1.52 or so exhaust as LT1 heads are good/ZZ4 ones were/are poor on exhaust hence wider cam split). This has a slight idle lope and great power up to ~425 flywheel, then the HOT CAM is the next/big step IMO (without going huge). It has a definite attitude and I don't recall it's power figures. look at camaroz28.com or other boards full of Lt1's......my dad just got his stock Lt1 running in his 240z and is having trouble putting traction down past 1/3 throttle in lower gears at present (won't slap his new tires on till he's played a bit more ) lots of specs on various roller combos (like your Lt1) at sallee chevrolet's site as well (quick search will find it) ahh, here's some specs rwhp from a dyno day in WA a few friends attended last fall, may be of help/ Ellis either had his 211/219 LPE in or something a hair bigger (not a HOT cam) ________________________ Kurtis Tamez ('97 Z28 automatic (bad/clogged cat)) - 249hp & 272 lb.ft. N/A, 350hp & 424 lb.ft. w/ NOS Joe Waldron ('94 Z28 M6)- Joe's biggest mod I believe is the LT4 Hotcam kit w/ Ed Write Program, 328hp & 327 lb.ft ME ('94 Z28 M6) - All I have is intake/exhaust mods mainly, 281hp 320 lb.ft, I still had the stock y-pipe on w/ hollow cat. conv., now have a Borla y-pipe so maybe that'll change a little Shaun Hoke ('95 Firehawk M6) - Shaun's hp run is stock w/ Hypertech & hollow cat. conv., 287hp & 318 lb.ft. Steve Sampson ('94 Z28 1LE M6) - Steve has mild porting w/ 1.6 roller rockers, springs, uh, I think that's about it for HP mods, Steve? 305hp & 330 lb.ft. And finally ~Ellis~, hmmmm, well you'll just have to ask him what he's got goin' on. I believe it's a cam-job w/ 1.52 RR's(?) and the computer program changes frequently, so you'll have to ask him about that. All I can say is his BEST HP run was at 316, and the best TORQUE run was at 338. ------------------ Of all the things I've lost, I miss my mind the most. [This message has been edited by Ross C (edited April 11, 2001).] Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted April 12, 2001 Share Posted April 12, 2001 Forgive me for asking...but I assume your swap is going into a "Z"..correct me if I'm wrong. First your have to decide: 1)What your most often driving range (RPM)will be 2)What the weight of the car is 3)What transmission you'll be using 4)What size tires you're using 5)Where you'ld like the Peak-Power to be (RPM-wise) 6)What you'ld like your car to do in the 1/4mile...this is usually a good point of reference for performance Once you've decided what your desired Peak-Power RPM needs are you then can address cam/intake selection & build around that...cam/intakes are usually listed by their Mfg's by their peak-power range(s). Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Guest RyalC Posted April 12, 2001 Share Posted April 12, 2001 I'll echo the previous comments on picking a cam - the key is what do you want to do with the car and what are your other parts of the equation (heads ported? how radical? street or race? do you need to pass emissions? where do you want the power - high rpm hp or low-end torque?). However, just to give you something to chew on below is a list of cams (and their specs) used on various LT1 cars. Manufact Part # Duration Lift (1.5) Lift (1.6) Lobe Notes LGM N365 211 220 492 492 525 525 112 1500-6200 LGM N365S 220 220 492 492 525 525 112 1800-6400 LGM N385 220 230 480 480 512 512 110 3000-6500 LGM N385S 230 230 480 480 512 512 112 3000-6500 CompCams 08-304-8 210 220 500 510 533 544 114 CompCams 08-306-8 230 244 510 540 544 576 114 heads, intake, headers,exhaust CompCams 230 242 510 510 544 544 112 " CCA-215-224-14 215 224 499 499 532 532 114 2200-5700 " CCA-220-230-14 220 230 510 510 544 544 114 2500-6000 CompCams 215 224 499 499 532 532 112 FIS custom blower cam CompCams Extreme Energy Series " CCA-212-218-12 212 218 488 495 521 528 112 1200-5200 mild " CCA-218-224-12 218 224 495 503 528 537 112 1600-5400 stk conv " CCA-224-230-12 224 230 503 510 537 544 112 1900-5600 gears " CCA-230-236-12 230 236 510 521 544 556 112 2200-5800 hvy mod " CCA-236-242-12 236 242 521 540 556 576 112 2500-6000 all mod " CCA-206-218-14 206 218 480 495 512 528 114 Nitrous/Blower " CCA-212-224-14 212 224 487 503 519 537 114 Nitrous/Blower " CCA-218-230-14 218 230 495 510 528 544 114 Nitrous/Blower " CCA 224-236-14 224 236 503 521 537 556 114 Nitrous/Blower TPIS 700-134 212 226 483 520 515 555 112 ZZ9 cam for93-94 TPIS 700-142 212 226 483 520 515 555 112 ZZ9 cam for95-97 GM 450 450 480 480 93 LT1 (stock) GM 203 208 450 460 480 491 116 94-95 LT1 (stock) GM 205 207 447 459 477 490 117 96 LT1 (stock) GM 203 210 446 449 476 479 115 96 LT4 (stock) GM 10185071 208 221 474 510 506 544 112 ZZ3* GM 24502586 218 228 492 492 525 525 112 LT4 HOT GM(Crane) 12370845 214 224 488 509 521 543 112 GM(Crane) 12370846 222 230 509 528 543 563 112 GM(Crane) 12370847 232 242 539 558 575 595 112 Crane 10hr0064 198 206 480 480 512 512 112 Crane 104124 214 220 452 465 481 496 112 Crane 104121 204 214 429 452 458 482 116 Crane 104125 208 214 438 452 467 482 112 Crane 109621 214 222 498 509 520 542 112 Crane 104141 218 218 498 498 531 531 116 Crane 10HR00013 214 222 488 509 520 543 112 Crane 10HR00017 214 218 488 498 520 531 114 Crane 215 224 499 499 532 532 112 FIS custom grind blower cam Crower LM-00402 219 227 498 518 531 553 108 DRM 222 230 508 528 542 563 LPE 74211 211 219 499 525 530 560 112 1600-5200 LPE 74216 213 219 462 471 493 502 112 1600-5200 LPE 74219 219 219 525 525 560 560 112 1600-6200 Lunati 50160 213 218 446 468 475 499 110 1500-5300 Lunati 50155 215 218 489 503 522 537 113 1500-5500 Lunati 50156 232 242 510 525 544 560 108 2000-6500 Lunati 50162 242 252 525 540 560 576 108 2200-6800 RRA1-218-224-A114 218 224 503 504 537 538 114 SealPwr 222 232 478 497 510 530 114 KenR MTI 210 220 500 510 533 544 114 MTI 230 244 510 540 544 576 112 Quote Link to comment Share on other sites More sharing options...
MYRON Posted April 12, 2001 Share Posted April 12, 2001 I am doing the Lt1 swap as well and have been looking into cams from Street&Performance (http://www.hotrodlane.com) and Tuned Port Specialties (http://www.tpis.com).. both these guys can help you with cam selection computer programming and many other performance mods... Check them out Myron Quote Link to comment Share on other sites More sharing options...
DavyZ Posted April 12, 2001 Share Posted April 12, 2001 RyalC, please tell me you didn't type all those specs out!!! If you did, bless you my son, but you have too much time on your hands!!! Quote Link to comment Share on other sites More sharing options...
Guest RyalC Posted April 12, 2001 Share Posted April 12, 2001 Nope - copy and paste. I believe in "re-use" whenever possible (in other words - I let someone else do all the work) The LT1 and T56 going into my 240Z came from my old '94 Z28. I sold the body to a friend who wrecked his Camaro at Atlanta and I kept the engine and transmission for my conversion. I'm still pretty tight with the f-body gang (specifically the Mid-Atlantic group - some good road racers in the bunch) so I get my technical information from practitioners! Quote Link to comment Share on other sites More sharing options...
