300ZXT half shafts question
VinhZXT
Guys,
Can I swap the input shafts for the 300ZXT half shafts? I bought an LSD several years ago and this is no normal LSD. The longer input shaft ( the longer half shaft) must go on the passenger side of the differential. If I stick the longer input shaft (the longer half shaft) on the driver side it won't go in all the way in. I have a pair of the 280ZXT half shafts but I know swapping the input shafts for these will be a PITA. If the input shafts for the 300ZXT can be swap easily I will have to buy them and the adaptors to use with this LSD. It is a 3.7 CLSD. I can open it up and take some pictures so you all can figure what type of LSD this is if it helps. Thanks guys
Vinh
