Guest damn240z Posted October 14, 2007 Share Posted October 14, 2007 I had all the info from this and zcars website and my computer crashed and I had to reinstall xp.... Now I can not find anything..... I need to know what was the setting for which hot wire sensor number it was. I think the little arrow direction was up and to the right and sensor cal was 1in and 1out, 2 out with z32 maf.... I had it all!!!! bill gates why!?!?!?! Its 430 in the morning and Ive been searching all night. Thanks ahead of time anyone. Quote Link to comment Share on other sites More sharing options...
Guest damn240z Posted October 17, 2007 Share Posted October 17, 2007 Ok, Im going to try it with my vague recollection of numbers, and an even vaguer description from apexi USA. Ill post my results.... Although I know Im not the first Im sure it will be useful. Did the old archives get erased? Tomorrow is go day followed by a dyno run with a SH***Y clutch. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted October 21, 2007 Share Posted October 21, 2007 Ok, Im going to try it with my vague recollection of numbers, and an even vaguer description from apexi USA. Ill post my results.... Although I know Im not the first Im sure it will be useful. Did the old archives get erased? Tomorrow is go day followed by a dyno run with a SH***Y clutch. And... ? What happened? Quote Link to comment Share on other sites More sharing options...
Guest damn240z Posted October 22, 2007 Share Posted October 22, 2007 Throttle setting is up and to the right, sensor in 1, out 1 for z31 maf; in 1 out 2 for z32 maf. My clutch was giving out really bad at 4500 but I still made 225hp and 303lbs with z31 eccs, apexi, volvo inj, 15psi, no IC, 20 degrees timing and 36psi base fuel and ign. I only ran and tuned it once due to poor clutch. The guy at the shop said he was really surprised no one on here could help me with this. Has NO ONE else used this? Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted October 22, 2007 Share Posted October 22, 2007 Throttle setting is up and to the right, sensor in 1, out 1 for z31 maf; in 1 out 2 for z32 maf. My clutch was giving out really bad at 4500 but I still made 225hp and 303lbs with z31 eccs, apexi, volvo inj, 15psi, no IC, 20 degrees timing and 36psi base fuel and ign. I only ran and tuned it once due to poor clutch. The guy at the shop said he was really surprised no one on here could help me with this. Has NO ONE else used this? I have tuned a lot of cars with the S-AFC II but not an L28ET. Every car is different regardless. I didn't know the S30's came with a linear throttle position sensor to even get a reading. I thought it was a three-state system only. Quote Link to comment Share on other sites More sharing options...
Guest damn240z Posted October 23, 2007 Share Posted October 23, 2007 Im using the 240sx TB and TPS and a z31 eccs with the apexi super afc(1). Quote Link to comment Share on other sites More sharing options...
