Stanza tb instead of 240sx?
palauoriginal
Megasquirt uses a potentiometer type TPS, not a switch type. Just measure it with a multimeter. Measure reistance and turn the TPS to see if it is a potentiometer(variable resistor). You can get one of those really cheap multi meters from harbor freight for $1.99 or $3.99
It will do both depending on which terminals you measure between.
There are 3 terminals on a potentiometer. The outer two will show a resistance that never changes. The middle and one end will show a resistance that increases as you move the TPS. The middle and the other end will show a resistance that decreases as you move the TPS.
My 240SX TB had both a 2 wire and a 3 wire connection. The 3 wire is the potentiometer and what I used for MS. The 2 wire was a simple switch that was closed when the throttle was either wide open or closed - don't remember which as I didn't use it and removed it.
