amorfin Posted October 29, 2007 Share Posted October 29, 2007 My RB26 came with a front sump from an RB25. I don't know how to weld, so the less welding the best for me. Last night after a while of taking measurements and getting ideas I realized that if I modify the oil pan to be kind of a rear-mid sump, I can use the RB20 oil pick up without the need of any modifications to it. And the oil pan will clear the drive shaft fine. So I was wondering if anyone has done this? And also, (this might be stupid but I will ask anyways) will the sump at this position have any negative effects? Thanks. Quote Link to comment Share on other sites More sharing options...
Cal Poly Zmanaustin Posted October 29, 2007 Share Posted October 29, 2007 You might find this helpful... http://myweb.westnet.com.au/mikeval/PDF/website%20part5%20Fit%20RB20%20sump.pdf I will give you a few ideas this weekend too. Quote Link to comment Share on other sites More sharing options...
amorfin Posted October 30, 2007 Author Share Posted October 30, 2007 Thanks Mark. I had already seen this and that is exactly what I was planning on doing. But as I said, last night I got this idea where with two simple cuts and welds at the right lengths on the RB25 oil pan, I would be able to just turn it around to where it clears the driveshaft but close enough to where I don't need to lengthen the RB20 pick up. Why do this? Well, I already have the front sump and after breaking my head for a while the modification seems pretty easy. So I might just try it to see if it works. I'll let you know what happens. I just need to find a place that can get the welding taken care of. You might find this helpful... http://myweb.westnet.com.au/mikeval/PDF/website%20part5%20Fit%20RB20%20sump.pdf I will give you a few ideas this weekend too. Quote Link to comment Share on other sites More sharing options...
Cal Poly Zmanaustin Posted October 30, 2007 Share Posted October 30, 2007 What you are proposing is very doable. I don't like to have too many welds in such a critical area, but if done properly it should work fine. I opted for a custom pan because I wanted to keep the windage trays. Quote Link to comment Share on other sites More sharing options...
