Zerrari GTO Posted November 27, 2007 Share Posted November 27, 2007 There is a place on my V/R rear tub that will need to have a small patch of glass that will wrap into the door jamb. It will need to be several layers thick so I was going to lay one or two layers and then rivet it to the door jamb to help prevent delamination from the body. I was then going to lay 2-3 layers over this riveted layer. My question is: Will the rivets present a problem later such as eruptions in the glass? Thanks. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted November 28, 2007 Share Posted November 28, 2007 I do not believe this will cause a problem. I don't know what material you'll be using (cloth, mat, or weight, etc), but you should be fine regardless. I assume no separation has occured anywhere on this quarterpanel? Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted November 28, 2007 Share Posted November 28, 2007 That should work. I did some similar work on my boat. I would lay 2 or more layers before riveting, then use chopped strand mat to go over the rivets because it's a little thicker than cloth and will hide the rivets better ( i'm assuming your trying to make it look flush). Quote Link to comment Share on other sites More sharing options...
Zerrari GTO Posted November 29, 2007 Author Share Posted November 29, 2007 Thanks for the feedback guys. I was planning on three-four layers (alternating stranded mat and cloth) over the rivets. I just wanted to be sure those rivets didn't come back to haunt me! Quote Link to comment Share on other sites More sharing options...
blueovalz Posted November 29, 2007 Share Posted November 29, 2007 I've got 1/8" aluminum rivets holding the entire quarter (no bonding at all) onto my car and have never, in 15 years had one work loose or move. Quote Link to comment Share on other sites More sharing options...
Zerrari GTO Posted November 30, 2007 Author Share Posted November 30, 2007 I've got 1/8" aluminum rivets holding the entire quarter (no bonding at all) onto my car and have never, in 15 years had one work loose or move. I was told that you should use rivets of the same metal as the material you are joining (steel rivets on steel body panels, etc.). Anybody have any experience with this? Quote Link to comment Share on other sites More sharing options...
blueovalz Posted November 30, 2007 Share Posted November 30, 2007 I'm guessing because of electrolosis. In my application it has never been a concern (kept very dry), and has never shown any sign of this action. The major reason I chose the softer material was a concern that the higher grip pressure of the steel rivets would distort, or worse, crack the fiberglass when installed. Quote Link to comment Share on other sites More sharing options...
